Author Topic: Kymco Like 50 4T: where does this hose connect to?  (Read 513 times)
Joachim16
« on: April 10, 2021, 07:14:19 AM »
Yesterday I adjusted the valve clearance on the scooter (7000 km), everything was fine at the inlet, the outlet was a bit narrow. Let's see whether this also has a positive effect on the run immediately after the cold start. There was also some soot in the exhaust gas recirculation, and removing it certainly didn't do any harm.
Now, here’s the question: In the engine compartment, on the right hand side, looking in the direction of travel, there is the open end of a hose, see photo. It appears to be a molded hose, bent almost 180 degrees, leading under the footboard.
Does anyone know where to connect the hose? I couldn't find a suitable position straight away.
Some other cables and hoses were also no longer in their holders / clamps, maybe an inspection at the precious owner's was not completely careful.
I haven't looked for the other end under the running board yet, that's my next action, if nobody has an idea here either.
I am curious, looking forward to read your ideas.
Thank you and have a good ride,
Joachim
Re: Kymco Like 50 4T: where does this hose connect to?
« Reply #1 on: April 10, 2021, 10:08:02 AM »
@Joachim16,
could be one of your hoses which connect airfilter box with the motor..
« Reply #2 on: April 10, 2021, 03:01:11 PM »
the closest thing I have to that hose is one that runs to one of the emissions devices under the right floorboard (under my right foot). See pic. The hose looks very similar but the positioning looks off..
Sullivaz7
« Reply #3 on: April 14, 2021, 11:30:47 AM »
My 06 GV 250cc has the secondary airfilter connected to a hose darn similar.
Can u show me a pic of where the other end of that hose connects to?
If not, describe please.
Sullivaz7
« Last Edit: April 14, 2021, 11:32:48 AM by Sullivaz7 »
« Reply #4 on: April 18, 2021, 07:14:26 PM »
Secondary air system, goes with one end finally to your carb.
