Author Topic: Which sparkplug?  (Read 4227 times)
guile
Which sparkplug?
« on: October 19, 2010, 11:54:11 AM »
Hi guys, does anyone know which sparkplug to choose? The NGK website suggests NGK Iridium CR8EIX, but someone on this forum suggested a NGK Iridium CR7EIX.  ???
Can anyone help me choose? ::)
Gijs
The Netherlands
pedro
  • Guest
Re: Which sparkplug?
« Reply #1 on: October 19, 2010, 12:56:17 PM »
I just looked it up on the NGK USA website, it says to use a CR8E standard non iridium type plug gaped at .028
http://www.ngksparkplugs.com/part_finder/motorcycles/partcloseup.asp?stocknumber=1275&partnumber=CR8E
Alex
« Reply #2 on: October 19, 2010, 09:01:26 PM »
I use the Iridium equivalent to the Std plug which was in the machine when supplied Kymco, cant tell you the number as I am not at home to check..still got the box I think , will look later
juice
« Reply #3 on: October 19, 2010, 09:34:30 PM »
The number represents the heat range you will most likely need . Higher numbers for more aggressive riding . You should probably stick to the manufacturers recommendation , unless you are very aggressive (racing) or very conservative . The person who recommended the lower heat range must think you are a more conservative rider . I really like the iridium plugs myself . Good luck .
Hoolander2
« Reply #4 on: October 20, 2010, 02:04:46 AM »
Kymco says to use an 8 in my carburated 2007 model.  I've replaced it with the iridium 8 and like it just fine.  You have the right part number.
guile
« Reply #5 on: October 20, 2010, 10:23:14 AM »
Thanks guys, will go for the NGK IRIDIUM CR8EIX.
guile
« Reply #6 on: October 28, 2010, 07:10:27 AM »
Has anyone tried changing a plug on a Xciting 500?? ??? ??
It's almost impossible without taking off all the plastic, and even then...  :-\
Anyone interested in a brand new iridium plug?  :D
Dr. Scooter
« Reply #7 on: October 28, 2010, 04:27:46 PM »
On My 07 it only takes me about 5 mins to change the plug
2007 Kymco Xciting 500
Modding a scooter is a beatiful thing!
bongoman
« Reply #8 on: October 28, 2010, 06:12:46 PM »
After the third time, I learned how to squeeze my hand into a claw that fits between the hoses and stuff. Of course, easier to change on a cold engine.
2009 Xciting 500
2015 Lance Cali Classic 150
Hoolander2
« Reply #9 on: October 29, 2010, 12:52:03 AM »
Yeah, guile, I tried it through the hatch.  No freakin way could I do it.  So did it while I had all the plastic off for a valve adjustment.  BTW the valve adj was no piece of cake either though I got better after the third attempt!  :D
Dr. Scooter
« Reply #10 on: October 29, 2010, 03:07:14 AM »
I go up from the bottom to pull the wire from the plug and do the rest throught the hatch
guile
« Reply #11 on: October 29, 2010, 09:46:02 AM »
I would need a child's hand to unplug the sparkplug  :'(
It runs fine now.
I hope never happens with the sparkplug in the future because it will be one friggin big operation to change it :(
I understand they solved this engineering flaw with the newer Xciting. Good work.
« Last Edit: October 29, 2010, 01:20:07 PM by guile »
msgtphil
« Reply #12 on: October 29, 2010, 01:12:38 PM »
Once you know where the spark plug is, it's a simple task. Shouldn't remove a spark plug wire by hand, anyway. Rather than a baby's hand, a good spark plug wire removal tool makes it a 10 minute task.
guile
« Reply #13 on: October 29, 2010, 01:23:53 PM »
There is a special tool under the seat of my Xciting. With one side you can remove the sparkplug itself. Is the other side meant to remove the plastic plug?
msgtphil
« Reply #14 on: October 29, 2010, 02:24:03 PM »
A spark plug wire removal tool is a specialized pair of pliers with tips designed to go around the spark plug wire boot (plastic), they are available at any auto parts store for $10.00 to $30.00. Careful though, I paid $30.00 for one that wasn't worth a crap, broke first time I tried to use it, took it back. Sorry, don't know brand name but if you have an AutoZone near I got a nice set there for about $15.00.
Edited to add - The tools supplied with any motorbike are barely functional and meant for emergency use. A good 3/8" drive rachet, spark plug socket with insert for holding plug snug, a selection of extensions and at least one swivel joint are essential for making plug changes a simple procedure. A torque wrench is also advised, one of the most common causes of parts falilure is over tightened fasteners.
« Last Edit: October 29, 2010, 08:59:15 PM by msgtphil »
