Author Topic: Kymco ck1 125 running issue  (Read 1005 times)
Kornsteven
« on: April 14, 2021, 10:41:58 PM »
Ok, so I bought this ck1 a couple of weeks back and finally got it running I cleaned the carb out as it was gummed up from old fuel, now as you can see the bike will idle no problem but as soon as you give it throttle it tries to die (does die if you keep the throttle), I have a feeling that in my stupidity I didn't drain the old fuel so I'm guessing the petcock maybe has been gummed up and also the fuel lines but what advice could you give that I should also look out for?
(I had to compress and zip the video as this site to let big files)
Thanks everyone
Re: Kymco ck1 125 running issue
« Reply #1 on: April 15, 2021, 12:22:26 PM »
yes, definitely dump out al old fuel and replace with fresh fuel.
Scoot that idles fine but dies with a slight opening of the throttle is a classic sign of a clogged pilot (slow speed) jet.
The opening in a pilot jet is a tiny, tiny passage that is one of the first things to clog on a carb.
Other things could be causing you problems but I'd start with the pilot jet. even if you think you cleaned it before, do it again!
scooterfan
« Reply #2 on: April 15, 2021, 03:05:42 PM »
Thanks everyone
It could be caused by quite a number of things:
1. Old fuel / water in fuel.
2. Air leaks (make sure the lines in the petcock system are not cracked / no air leaks at carb gaskets / connections ).
3. Dirty fuel filter.
4. Blocked air filter.
5. Faulty spark plug.
6. Carb jets still not 100% clean ? (Soak the jets for about 2 days in white vinegar and blow out with an air compressor).
Just a couple of causes I can think of.
Kornsteven
« Reply #3 on: April 15, 2021, 11:06:25 PM »
Thanks People! Looks like I have a few things to do at the weekend!
Thanks again
