Hi everyone. Today I adjusted the valve clearance. But I noticed that turning the engine manually (clockwise and I don't know if it's correct but I think so because I have the flywheel on the exhaust side) it made a bad noise like a coffee grinder. Two years ago I didn't remember making this noise. Is the engine gone?
Second question:
When positioning the flywheel the manual says to align the "T" mark on the flywheel with the mark on the crankcase cover. I don't understand well where I should see a "T". I only see two vertical marks on the flywheel. Anyway, I put the cover mark exactly in the middle of the two flywheel marks. But on the manual the picture is different (the cover mark is aligned with the right flywheel one). Do you think I did wrong and I have to do all the job again? See picture.
Thank you for help
Turning the engine clockwise from the flywheel means you have turned the engine “clockwise”.
I have no knowledge about your scooter models but there is another way to make sure the camshaft is at the correct position when you do valve clearance settings on a two valve engine.
When the camshaft is at the correct position (piston at TDC) - both camshaft lobes will be facing towards the rear end (back wheel) of the scooter.
With the camshaft lobes in this position, the timing marks (according to the service manual) should also line up correctly.
So when the cam lobes are facing backwards on your engine and tou cant see the timing marks, just turn the flywheel very slightly untill the timing marks are lining up correctly. At this point you can do both valve clearance adjustments.
I assume you did not hear the strange engine noise just before you did the adjustments ?
If not, I think there is a possibility that the adjustments have been done incorrectly - and the piston might be hitting the valves when the engine is swinging.
Hopefully this is not the case - otherwise you might have bigger problems.
