Author Topic: People Gti 125 won't start  (Read 4739 times)
Faber32
Re: People Gti 125 won't start
« Reply #45 on: May 06, 2021, 11:58:54 AM »
Sure!  :)
agilebda
« Reply #46 on: May 10, 2021, 02:34:12 AM »
Charge the battery. I had the same issue years ago.
Faber32
« Reply #47 on: May 10, 2021, 06:09:34 AM »
Hi! This was one of the first attempts I did. I bought a new Yuasa, I put it on but it did the same problem unfortunately
« Reply #48 on: May 10, 2021, 10:26:31 AM »
@Faber32, salve
How it's going with your head gasket?
Any news about the scoot?
Faber32
« Reply #49 on: May 10, 2021, 10:29:06 AM »
Hi Ruffus :-)
No news, still waiting for a response about the overall situation of the engine components.
I'm concerned about the possible causes that led to the head gasket failure. Because I had no engine light while driving, nor overheating issues.
I'll keep this topic posted as soon as I know something more  :D
Faber32
« Reply #50 on: May 20, 2021, 10:30:41 AM »
Hi, I've seen the head gasket in my hands. The mechanic says it's due to cold engine revving and hard accelerations. I don't know... If I can I'll post some pics
« Reply #51 on: May 20, 2021, 03:52:04 PM »
Hi, at least the main source is found. (gasket)
Yes, cold revving and kind of things make sense.
Okay, bearings could have suffered, but this is easily to be seen when head and cylinder are off. It ran with its dry cylinder and probably steamed its coolant out.
In the industry we had rubber bearings, size of a soup plate, which were water-lubricated, worked for years without probs. I know, I compare....
Faber32
« Reply #52 on: May 20, 2021, 05:11:45 PM »
The fact is that I don't think it really took such a beating or revving. Anyway it doesn't matter, I'll also change the oil as soon as I can because it could be contaminated by blowby :)
« Reply #53 on: May 20, 2021, 07:29:56 PM »
Coolant in oil is easy to dedect. Makes it greyish, and, should be some grey foam at/on your dipstick and thread...
Faber32
« Reply #54 on: May 20, 2021, 09:00:08 PM »
You're right. In my case probably contamination is minimal, but an oil change costs 15 dollars so I'll do it anyway :-)
