Author Topic: LIKE 200i digital clock renewal  (Read 1139 times)
« on: April 23, 2021, 02:15:47 PM »
Dear colleagues,
an technical item on an machine which is not functional, every time I watched my clock....is for nothing.
So, something had to be done. Thanks to my stock the right item was in no time available.
The LIKEs cockpit has to come off, 2pc # and 2pc 8mm screws and its in your hand.
 Dismantling is very easy, just take care not to demage or scratch your odo-display.
Removing all cables makes working easier. All plugs and sockets to several switches are selfexplainatory.
Testing an used item is an good idea too, also when in place. Requires 12 V on a red and green cable.
(pls see pics)
Re: LIKE 200i digital clock renewal
« Reply #1 on: April 23, 2021, 02:35:12 PM »
How did you get that case apart?!
« Reply #2 on: April 23, 2021, 03:04:44 PM »
Nice job Ruffus!
If I was still able I'd make this a DIY sticky for LIKE200i.
The 'repaired' forum no longer permits me to do that.
« Reply #3 on: April 23, 2021, 04:37:03 PM »
Thanks, Ruffus. Always love to see your work and really 'like' the pics of the components taken apart!
« Reply #4 on: April 23, 2021, 07:03:15 PM »
Thank you all.
@CROSSBOLT, those odo body is fixed with four # screws to the "cockpit" and the item itself is hooked with four latches (weak, be tender) together to hold the "glass" and white facing. All in all just an unbolting exercise.
