Author Topic: Carburetor problems!!!  (Read 1593 times)
Williambarnhart91
« on: May 05, 2021, 01:10:15 AM »
It's on a kymco xciting 500. It has a carburetor with the normal float but it also has a fuel pump. I can pull the gas hose off at the carburetor and its is pumping plenty of fuel. I cleaned the carburetor and everything looked fine. It will not run if I put everything together but if I take the carburetor loose from the intake Boot and hold it back about a quarter inch to where the gas is literally spraying out of the carburetor it will run just fine but the second I put the carburetor on it dies out. I tried to pull the air tubes off and there was no difference. It's like the gas is coming out as a liquid instead of spraying? What am I missing? Has to be something stupid that I'm overlooking lol is there a pressure switch for the fuel pump? Already reset the float.
Re: Carburetor problems!!!
« Reply #1 on: May 12, 2021, 08:11:58 AM »
sounds like the float is stuck or your needle to shut the fuel off in the carburetor or float level to high where it's not shutting off.
Fuel pump is a vacuum model on carbureted Kymco's with no regulator that I'm aware of.
« Last Edit: May 12, 2021, 08:15:55 AM by Kansas kymco »
sissymary
« Reply #2 on: May 21, 2021, 04:32:41 PM »
Does the rubber diaphragm have a tear in it? Diaphragm and slide are the same part.
