Author Topic: Need help asap  (Read 583 times)
Keoki71
Need help asap
« on: May 06, 2021, 04:23:24 AM »
I’m new working on a kymco agility 50cc 2016 , I put a tight belt on my clutch and variator, there was no slack and that time I didn’t know anything, just order a variator and clutch performance kit and slap everything on, when I start it had a loud grinding noise, I crank it over couple times to see we’re the problem is coming from, my hunch was the variator so I put the old variator and old belt, and start it up and ran good few secs and made that grinding binding noise, so I’m at point I give up and throw the bike away, plz help.
Re: Need help asap
« Reply #1 on: May 06, 2021, 11:53:55 AM »
Any chance you can shoot a video of it with the old parts on?
Don't give up, yet!
big blue
Re: Need help asap
« Reply #2 on: May 06, 2021, 09:50:27 PM »
I assume this scooter has a backup kick starter.  Does it work now after your belt replacement? What sometimes happens is that the starter return spring slips out of position and will cause a grinding noise. Does the starter lever return to the top position after you  push it down? Check out this video...
Re: Need help asap
« Reply #3 on: May 06, 2021, 11:34:24 PM »
Nice find Blue!!
Keoki71
Re: Need help asap
« Reply #4 on: May 13, 2021, 05:30:08 AM »
Thanks guys for reply’s and helping me out, but I am idiot found the solution to the nut that holds the gear and the variator was loose I impacted gun it, thought it was tight, as I start it the nut comes loose causing the fan to rub against the kick starter gears
