Author Topic: Extended forward controls  (Read 3492 times)
Ironhorsecustomz81
« on: May 06, 2021, 07:19:53 PM »
Ok guys so has anybody found or made any forward control extentions for a venox 250?
I have a set lying around from a 03 sportster and im thinking about seeing if i can revamp them to work with the venox. I already hot rid of the foot pegs and replaced them with foot boards. Any thoughts or advice before I start would be greatly appreciated.
gt alex
Re: Extended forward controls
« Reply #1 on: June 17, 2024, 08:26:05 AM »
I just bought a kit for a Honda Magna 250 which I hope will go on my Venox with little or no trouble.
I come with brackets to move the controls forward 100mm and up 30mm and extended gear rod and brake rod.
gt alex
« Reply #2 on: July 10, 2024, 11:51:56 PM »
The Magna 250 forward controls are on, only minor adaption was required.
The main difference is Venox controls have a larger 12mm mounting holes so the brackets needed drilling to fit the frame and the controls needed bushing to locate on the new brackets (I used a 5/16 fuel line and washers must be used).
The kit came with a longer gear rod and brake rod.
The gear rod needed about 10mm cut from each threaded end.
The brake rod was perfect but the Kymco pivot pins have round heads and the rod needs pins with a flat ground on one side of the head.
Once installed a longer brake pedal adjuster bolt was needed and although alignment was off a bit it works well.
gt alex
« Reply #3 on: July 10, 2024, 11:53:47 PM »
other side
