Author Topic: battery size problem  (Read 4880 times)
spikebites
Re: battery size problem
« Reply #15 on: August 14, 2021, 05:58:17 AM »
Remove and measure your current battery.
Take measurements to Walmart,  auto parts store, Amazon. ....buy best you can afford.
Work from measurement,  not a chart for sure results.
Oh I see, I thought they would be a universal size.  I guess I'll have to open the seat up again.
Thank you!
spikebites
« Reply #16 on: August 18, 2021, 01:34:00 AM »
Thank you!
EDIT:  Figured it out.
« Last Edit: August 18, 2021, 02:36:22 AM by spikebites »
An Orange Crush
« Reply #17 on: September 26, 2021, 10:10:39 PM »
Twice now I have ordered a replacement battery for my 2016 Kymco Downtown 300i scooter and got the wrong size - physically too big .
Both times the battery was listed by the seller, Battery Clerk, as the appropriate size battery.
Where can I find and order the correct size?
So far I am still nursing the original battery along with lots of trickle charging, but that is not going to last much longer.
Don
I actually had the opposite problem in that the original battery simply wasnt large enough (2011 DT300i) and did NOT want to start on hot days.
I read through many threads from others who had the same issue and posts were made regarding resetting the TPS, checking valve clearance, voltage etc and then one day a guy who was about to give up bought himself a battery that was oversize, he cut some of the plastic to make it fit and his problem went away.
I followed suit and my problem with starting on really hot days went away too.
2011 DT300i
2009 SYM HD200 (sold)
2009 Kawasaki Brute Force 750i
2023 Kymco AK550
A couple really nice shiny helmets
"I`m a man, but I can change. If I have to.
.....I guess....."
JJJoseph
  • Kymco Sento
« Reply #18 on: September 26, 2021, 11:20:38 PM »
Try your dealer, OEM stuff fits and works!
There's not many Kymco OEM dealers.  You're better off using the Yuasa website to size your battery.
« Reply #19 on: September 27, 2021, 01:52:40 PM »
Best bet after 67 years of doing this---your dealer.
« Reply #20 on: September 28, 2021, 09:22:45 PM »
Wallyworld and Orielly auto parts both carry motorcycle batteries,  just take your old battery in and get the same size like Stig suggested would be the easiest.
