Author Topic: Vibration  (Read 1273 times)
roaldn
Vibration
« on: July 28, 2008, 12:34:08 PM »
Hi Y'all
I own a 2007 People S200 that I bought in Florida last winter. It now has 6500 km (4000+ miles) and running great. Except for a problem with vibration. It started shortly after I began riding it, then it seemed to go away again but now it is getting really bad. It happens when you first rev up to begin moving  and as you pick up speed it goes away.
I read elsewhere about the gear oil fill quantity. When I changed the gear oil the first time I too filled to the underside of the fill hole. This resulted in oil leaking out from the drain hole in the bottom of the air filter box. The gear box has a vent tube going into the air box. This went on for awhile and made a mess of the rear end of the scooter. I then drained the gearbox again and refilled with 180 ml and have not had any leakage since.
If anyone know anything about the vibation problem, I would like to hear about it.
olbull
Re: Vibration
« Reply #1 on: July 28, 2008, 06:10:47 PM »
Sounds  like the  clutch  maybe glazed..Simple  fix....Hold  your rear  brake tightly  locked and rev  your engine  for  a few  seconds..This will  remove the glaze  off  the  clutch  plates..
Your  noise/vibration  should be gone
OlBull
2007 P250
If  your  not the lead dog the  scenery never  changes
roaldn
Re: Vibration
« Reply #2 on: July 28, 2008, 08:02:25 PM »
Hi again.
This note is for OlBull.
You were right on the mark. Problem solved using your suggestion.
Thanks a lot.
roaldn
Zimmerman
  • Northeastern Pennsyvania USA
Re: Vibration - error in manual - don't over fill gear oil.
« Reply #3 on: October 30, 2012, 03:11:04 AM »
I read that the owners manual is in error.
It says to fill until oil comes out the bottom of the fill hole.
That's not right - that would be too much oil.
I think Kymco released a service note saying to only ad the specified amount and no more.
Kevin
Kymco Yager GT200i
Kymco People 150
Yamaha Riva 125
ScooterWolf
Re: Vibration
« Reply #4 on: October 30, 2012, 02:30:26 PM »
Check your roller weights. They may be off balance, or out of shape. I had a similar problem with my Yager GT 200i and it went away when my mechanic say that the weights weren't symmetrical.
Hope you solve the problem.
-Wolf
old geezer
Re: Vibration
« Reply #5 on: October 30, 2012, 02:40:33 PM »
The op made that post in July of 2008. I'll bet he found the problem way before now.
