Author Topic: Kymco air filter  (Read 487 times)
Robyn
Kymco air filter
« on: May 17, 2021, 04:59:45 PM »
I have just purchased a 2008 Kymco Bet & Win 250 and it was running really rough.  Drained the old fuel, changed spark plug, oil and gear oil and added coolant.  I want to check the air filter but do not have a service manual for it...can anyone tell me where to find the air filter?
big blue
Re: Kymco air filter
« Reply #1 on: May 17, 2021, 05:39:59 PM »
Robyn
« Reply #2 on: May 17, 2021, 06:07:18 PM »
Thank you, this will be very helpfull
« Reply #3 on: May 17, 2021, 06:17:31 PM »
You might want to add some Techron  fuel cleaner to your fuel , about a ounce per gallon.
Robyn
« Reply #4 on: May 18, 2021, 02:38:47 PM »
Thank you, we did that.  I think the next step will be to check the air filter and clean out the carburetor.
« Reply #5 on: May 18, 2021, 03:06:16 PM »
I've purchased several used Kymco's that have sat for a few years. Every one of them needed the carburetor cleaned to even run. One was so bad I just replaced the carburetor.
I always recommend using O-E fuel (no ethanol ) and I add a ounce per gallon of Seafoam as a fuel stabilizer if the scooter sits for any length of time.
pa-outdoorsman
  • Pennsylvania
« Reply #6 on: May 18, 2021, 05:38:33 PM »
I'm a big believer in ethanol-free gasoline. Considering how little fuel our scooters and other small-engine items use, it's really a very small difference in up-front fuel cost to get the ethanol-free gas. I think the savings on the back end in terms of lower maintenance costs and problems is much greater than the added up-front expense.
2018 Kymco UXV 450i
2021 Honda ADV 150
airshot
« Reply #7 on: May 18, 2021, 10:17:47 PM »
Ethanol fuel will only cause an issue if your fuel system is dirty to begin with.  Tha alcohol is a serious cleaner and loosens any crud it comes in contact with. You should run a fuel conditioner at all times to keep the system clean, even with ethenol free fuels!!  I cleaned my fuel system and converted the hoses on my 1983 boat engine, been running 10% for almost ten years with no issues. My neighbor is an engine mechanic, never saw a real problem with ethanol fuel as long as system is clean to start and kept clean!!!
« Reply #8 on: May 18, 2021, 11:44:00 PM »
I do not agree with you. Ethanol fuel attracts water for long periods of storage which causes major corrosion and carborator issues.  If you are using it this is not a issue.  Pure ethanol is a very corrosion fuel, use to race boats Blown alcohol flat bottom.  I also worked in the hydrocarbon industry.
I have never seen a airport or Marina that sells ethanol blend fuel for a reason.  I'll see if I can find a picture of my old race boat from 40 years ago from the Southern Drag Boat Association.
« Last Edit: May 19, 2021, 12:43:40 AM by Kansas kymco »
« Reply #9 on: May 19, 2021, 02:08:51 AM »
picture posted for Kansas kymco -
« Reply #10 on: May 19, 2021, 06:28:41 AM »
Sorry for the poor quality picture but most of my photos from that time period were destroyed in a flood in 1979.  This was my BGF boat (Blown gas flatbottom)a few decades before I was fat, grey hair and old.
Thank you Iahawk
« Reply #11 on: May 19, 2021, 03:53:53 PM »
That’s a great old pic!
