Author Topic: Kymco ck1 125 clutch torque?  (Read 475 times)
Kornsteven
« on: May 23, 2021, 03:38:51 PM »
Hello just wondering if anyone knows of any torque settings for the clutch on the ck1 125?
Or if anyone has access to a manual would be amazing
Thanks in advanced
big blue
Re: Kymco ck1 125 clutch torque?
« Reply #1 on: May 23, 2021, 05:15:49 PM »
Kornsteven
« Reply #2 on: May 23, 2021, 06:42:20 PM »
Thanks for the link, but that is for the "ck" I have the "ck1"
Thanks anyway
JJJoseph
  • Kymco Sento
« Reply #3 on: May 27, 2021, 07:19:16 AM »
What "torque" are you looking for?  The large nut that holds it together? There is no "torque setting", you just tighten it to the stop.  Or is there some other "torque setting" you're looking for?
« Reply #4 on: May 27, 2021, 10:03:27 AM »
@Kornsteven,
(pls see pics) the big 39mm nut I do as hard as I can on this flat piece without stripping the flange, holding the clutch pulley with an oil-filter spanner (belt type).
The assambly nut , 17mm, I fasten to 90nm with a torque. Both nuts get a few drops of blue Loctite 243 on it just in case.
JJJoseph
  • Kymco Sento
« Reply #5 on: May 29, 2021, 03:48:52 AM »
@Kornsteven,
Yes, that's sounds just about right.  Or that's exactly how I do it, and never any problems!
