Author Topic: Ignition wire  (Read 498 times)
kjems
Ignition wire
« on: May 27, 2021, 02:50:01 PM »
I just bought a New ignition lock after someone tried to Steel my scooter.
But when i took out the old i could not see that the black wire was connected anywhere.
https://ibb.co/Vg32JZN
https://ibb.co/ZgNytL3
Is that ok not to connect that on the New as well?
« Last Edit: May 27, 2021, 05:19:11 PM by kjems »
Re: Ignition wire
« Reply #1 on: May 27, 2021, 03:20:04 PM »
Probably not OK, if it was part of the wire group leading up to the ignition - then it likely needs to be connected there.
Photos of what you have would help.
Old and new parts, and wire group.
kjems
Re: Ignition wire
« Reply #2 on: May 27, 2021, 05:18:01 PM »
My thought also.
But when i took the old one out, i could not see any wire or holes where the plug could fit.
And it seems to start and function ok?
Tried to link to a few photos also.
Re: Ignition wire
« Reply #3 on: May 27, 2021, 06:50:10 PM »
My thought also.
you say it starts and runs OK?
Well, shoot - I see the same wiring on some used ignitions for the LIKE - with that lone B/W wire.
If it runs...... I got nothing better than that for you!
Re: Ignition wire
« Reply #4 on: May 27, 2021, 07:19:00 PM »
@kjems, (pls see pic)
Yes, there is one black "leftover" cable. Not sure which model uses this as an appliance.
kjems
Re: Ignition wire
« Reply #5 on: May 27, 2021, 08:59:46 PM »
Yes all works well. And nice to hear im not alone with that left over cable  :)
Thanks Jesper
