Author Topic: Removing Plastic  (Read 1321 times)
Vision
Removing Plastic
« on: May 28, 2021, 10:20:40 PM »
Does anyone know of a video or tutorial on removing the plastic from the handlebar/console area? I don't want to be making the process up as I go along.
aschrauth
Re: Removing Plastic
« Reply #1 on: May 29, 2021, 05:26:23 AM »
I have written up a fourm that shows the removal of the front plastic on a kymco 125cc. All you have to do is remove some screws.. Ill link it below.
https://1drv.ms/w/s!AgN5wfZebcXSjQtHllztH7IcKd7C
Kymco 125cc
Wolf Rx50 BBK 80cc
Vision
« Reply #2 on: May 29, 2021, 04:15:48 PM »
Thank you so much for this. Big help.
Vision
« Reply #3 on: May 29, 2021, 08:34:58 PM »
With your tutorial I got the plastic removed. Two questions:
How did you get the bulbs out of the console, is there a trick? Mine are stuck pretty good and am afraid of damaging them.
Do you have any idea why the dashboard clock would stop working? Mine's been out for a while and I'd like to get it back.
« Reply #4 on: May 30, 2021, 08:58:10 AM »
@Vision, maybe this helps with your clock.
Had to do this recently on one of my LIKEs...
https://www.kymcoforum.com/index.php?topic=31008.msg217425#msg217425
Vision
« Reply #5 on: May 30, 2021, 08:47:31 PM »
Thanks Ruffus, that helps. Is there a trick to disconnecting the speedometer cable from the dash? I unscrewed the collar piece but the center wire remained connected to the dash preventing the cable from being disconnected.
aschrauth
« Reply #6 on: May 31, 2021, 04:48:25 AM »
I recently converted all of the instrument cluster bulbs to LED. The sockets were practicly glued in my spedometer, all I did was take a pair of curved needle nose pliers and wrapped the ends in electrical tape and slowly worked them out of the hole. Just make sure not to damage the wiring.
As far as the clock I believe it has an internal btton cell battery but im not sure if it can be removed non destructively.
Kymco 125cc
Wolf Rx50 BBK 80cc
« Reply #7 on: May 31, 2021, 08:24:59 AM »
@Vision, for speedocable:
I'm not sure whether it's the same as on on my LIKEs, but you might see a big silvery grooved nut which holds the speedocable. Just take a plier and unscrew.
« Last Edit: May 31, 2021, 08:36:41 AM by Ruffus »
Vision
« Reply #8 on: May 31, 2021, 11:43:34 AM »
What bulbs did you use? How many are there?
Vision
« Reply #9 on: May 31, 2021, 11:48:52 AM »
I did that, and after removing the grooved nut it exposed a metal wire (running up the middle of the speedocable) which was still attached to (I assume) the gauge. After giving it a pull or two I was concerned about damaging something so I stopped. Don't know what the next step is.
« Reply #10 on: May 31, 2021, 01:31:30 PM »
You're right on track.
This speedo cable get stuck a little within its sheath.
Old grease might act as glue. Just wiggle gentle with pliers and pull it out.
NO spray using there, might come into your gauge and messes up!
