Author Topic: Is this bolt for the oil also?  (Read 1646 times)
conan222
« on: May 30, 2021, 09:07:31 AM »
Hi,
Can you please tell me what this bolt is for as it appears to be linked to the main oil sump but the oil drain plug / bolt is underneath on the other side of the bike?.
Thanks for any help.
Andrew
Re: Is this bolt for the oil also?
« Reply #1 on: May 30, 2021, 10:09:18 AM »
That is the drain for oil. The big cap on the other side is the strainer for oil.
Onekneedown
  • ride more, talk less
« Reply #2 on: June 09, 2021, 05:34:00 AM »
No it is not for the oil also.  The oil drain plug is under the bike with the strainer attached.
« Reply #3 on: June 09, 2021, 11:09:34 AM »
I could be wrong...I thought I was wrong once....but I wasn't! Har, har!
Would you care to place a bet? C'mon, let's make a bet! Wish I had some money! Har, har!
« Reply #4 on: June 09, 2021, 11:26:15 AM »
Yeah, your bolt is for the oil.
17MM Karl?, most of them??
« Reply #5 on: June 09, 2021, 04:38:52 PM »
Yep. 17 mm for drain bolt. 15/16" (23 mm) for the strainer....I think....I could be wrong..?...naaahh!
Onekneedown
« Reply #6 on: June 10, 2021, 01:26:32 PM »
I was wrong once too.  But still not changing my oil from that location ??
« Reply #7 on: June 10, 2021, 02:57:30 PM »
That's okay. Whichever works best for you. That way you get the screen and the oil together. See, no prob, Bob!
« Reply #8 on: June 11, 2021, 10:48:08 AM »
....until that pot-metal strainer cap's hex head strips and rounds off, from over tightening!
Have seen lots of scooter posts after this happens!!
The actual oil drain plug (usually on the SIDE of the case) is made from much better metal....never heard of the head of these stripping.
« Reply #9 on: June 11, 2021, 11:59:22 AM »
VERY good point!
JJJoseph
  • Kymco Sento
« Reply #10 on: June 13, 2021, 06:36:41 AM »
On my Sento, they're both 17mm
« Last Edit: June 14, 2021, 06:26:08 AM by JJJoseph »
« Reply #11 on: June 13, 2021, 10:19:03 AM »
They're both 17mm
My bad. The oil filter cap on the DT300i is 23 mm and is considerably larger than the strainer cap.
