Author Topic: People 150 Axle Nut  (Read 883 times)
Shumbody
People 150 Axle Nut
« on: June 07, 2021, 07:33:22 PM »
Just changed my gear oil, and went around the block to check the work. When I pulled back in my driveway, I saw a piece of hardware that I hadn’t seen before. Turns out it was my axle nut, and when I parked the bike the axle had just slipped out of the arm!
Don’t need to tell you how terrifying it was to know that a longer ride might have resulted in one I did not return from. It seems that either the axle or nut might’ve cross threaded as well. As I recover and start to put this back together, what should I be looking for/aware of, and where can I find resources to make this safe again?
Re: People 150 Axle Nut
« Reply #1 on: June 07, 2021, 08:18:55 PM »
@Shumbody,  welcome to the forum.
Are we talking about this nut (pls see pic)?
-If is this the case, it might be necessary to remove the wheel and check whether one or both threads have suffered.
-only putting back the axle nut without being sure its unharmed or not, I consider too risky
-the nut is not a very hard metal
-axle material in comparison is hardened/nitrated
-so it's more likely that, your nut has lost its thread, means you need a new nut.
This nut is not to get at hardware store, but ordered from a Kymco dealer of your choice.
Check all this out and ask here again, if something seems to be unclear.
« Last Edit: June 07, 2021, 08:20:35 PM by Ruffus »
JJJoseph
  • Kymco Sento
« Reply #2 on: June 08, 2021, 07:57:27 AM »
If you can't find a genuine Kymco nut, these nuts are standard across many other makes and models.  Check with your local Honda or Yamaha parts people if that's the case.
Shumbody
« Reply #3 on: June 14, 2021, 10:39:24 PM »
Thanks for the replies. I think it best to find a new nut. Anxious to get back on - great riding weather lately!
stuo
« Reply #4 on: June 15, 2021, 02:32:52 AM »
You are one lucky dude!
2009 GV 250
« Reply #5 on: June 16, 2021, 11:25:35 AM »
Watched a youtube where a rider on a vintage Vespa filmed his ride while his rear axle let go.
He went down, then bounced onto a sidewalk. No one was behind him, fortunately.
« Reply #6 on: June 16, 2021, 12:40:17 PM »
@Shumbody, when you found this axle nut, please, even you're anxious to ride off, take your time to check axles thread. There must have been a reason WHY this nut fell off.
-sloppy tightening
-bearing worn out
-overtighened
-wrong nut at all mounted
-distance spacer (if standard on this model) missing
