Author Topic: X-Town 300i Engine Oil Change  (Read 1376 times)
« on: June 19, 2021, 03:04:39 PM »
Time rolled around for my second inter-service oil change so I decided today was the day.  Remembered the drain plug is a 17mm bolt (thank you John Grinsel) and where to access it.  All told the entire job was probably 15 minutes?  A vast improvement on the first time I did this bit of a job.  The manual is a bit vague on the capacity for the 10-40W oil to fill up stating:
Full capacity: 1.1 L (1.16 US qt)
Exchange capacity: 0.9L(0.95 US qt)
After leaving it to drain fully for about 10 minutes, I put the sump plug back in and decided to go right down the middle with a measured 1 litre of oil poured in.  Guess what, spot on the top of the full mark on the dipstick.  Will no doubt need checking and possibly topping up in 100 miles or so, but one litre seems a pretty good start point?
Re: X-Town 300i Engine Oil Change
« Reply #1 on: June 19, 2021, 05:08:11 PM »
I worry that some day I'll get so busy with the clean up......that I'll forget to put the new oil in.
(Autos and scooters)
And don't forget the cap or dipstick!!
Stick
« Reply #2 on: June 19, 2021, 05:12:23 PM »
Photos would've given this post more punch.
An 'action shot' of oil draining, drain plug resting in oily Bounty towel, smoldering cigarette near a coffee cup, e t c.
« Reply #3 on: June 19, 2021, 07:31:32 PM »
Yeah, very moody concept Stig, but I figured we could all visualise that and moreover I ain't about to teach a load of Grannies how to suck eggs!  Plus I gave up smoking 30+ years ago.
« Reply #4 on: June 19, 2021, 08:36:57 PM »
Stick
Happened to my company truck at a quick change place.  The guy come in after he pulled the truck out and asked if the oil pressure gauge worked. I responded yes and he backed it back in and filled it with oil.
mrmike
  • Syuracuse, NY
« Reply #5 on: September 20, 2021, 03:37:29 PM »
Did you remove the second plug to check the factory filter/screen?
« Reply #6 on: September 21, 2021, 10:46:40 AM »
Yes Mike I did and it was as clean as the proverbial whistle!  The spare screen I bought may not be needed for some 000's of miles?
« Reply #7 on: October 17, 2022, 02:15:45 PM »
Further Oil Change completed today.  It's now taking almost as long to get the tools out, then clean them and put them away as it takes to drain & refill the oil!!  That's as it should be though I guess.
« Reply #8 on: October 17, 2022, 03:27:07 PM »
I think is Kymco translation means no filter change and with filter change.
« Reply #9 on: October 17, 2022, 06:42:38 PM »
I put about 0.95l in this time Karl and that seemed just right. Maybe my imagination, but the engine does sound smoother.
« Reply #10 on: October 17, 2022, 07:22:46 PM »
ALWAYS smoother, more power and rides better after both changing oil and washing! Waxing makes it go faster and smell better, too! Har, har!
« Reply #11 on: October 17, 2022, 07:26:52 PM »
“Washing”? Ah, knew I forgot something. Maybe next month…
« Reply #12 on: October 17, 2022, 10:05:23 PM »
On my scoots the larger amount is needed when refilling a shattered engine after it has grenaded.
The lesser figure refills a healthy engine.... or box of gears.
Apparently a bit of oil hides from that drain plug.....and the service writer knows this🙃
« Reply #13 on: October 18, 2022, 12:20:08 PM »
Yes Stig, if you think about it, there's lots of nooks and crannies in yer average infernal combustion engine!
« Reply #14 on: October 18, 2022, 02:36:24 PM »
Yes, as I was disassembling and reassembling my S200 engine I noticed that a lot of oil stays behind, especially if you’re only draining through the oil screen. Draining through the actual drain plug will remove quite a bit more oil.
