Author Topic: Lubricate Throttle Grip  (Read 2397 times)
Re: Lubricate Throttle Grip
« Reply #15 on: September 06, 2021, 03:30:10 AM »
this may sound a little silly..but are you sure you're seating the hex wrench in there all the way? I've had a few hex bolts where I didn't think the wrench would fit and it took a little force to get it to seat properly.
I know my hex wrench set has a few in between sizes (2.5 mm comes to mind) but i've never seen a size in between the 6,7 or 8.
« Reply #16 on: September 06, 2021, 10:06:24 AM »
@Vision, if it's not a 8mm inbus, take a little bit bigger torx socket, drive it in with a hammer, unscrew. Replace bolts with something adequate.
One possibilty is this, the second which I would try is a 1/4 inch allen key, which is between 6 and 7 mm.
