So I took off my kill switch on the stand because it was messing everything up. The bike started to work fine, but sometimes, If I had the kickstand a certain way, it wouldn't start even after I took out the switch (maybe I didn't take all of it out idk) either way. It was killing the battery, but it would turn on fine after a couple of tries. So I am trying to get it to work yesterday, and at first, I thought the ignition button got stuck cause it didn't stop attempting to turn over. I got it unstuck, and it was still trying to start; luckily, cause the battery was dying, I had it hooked up to a new fresh battery ( i didn't have the tools on hand to switch out the batteries). So while it's hooked up, I waited for it to get a little charge. I hit the ignition, gave it a little bit of gas just in case, and it's just attempting to turn over and over and over. I quickly put the kickstand down, hoping it would stop with the kill switch. It's still going. I hit the hand kill switch by the ignition still going, I took the key out, and it was still going. In a panic, I disconnected the fresh battery so it wouldn't keep charging, and the battery died, thankfully. I thought it was a glitch once the battery died, and it couldn't keep turning, and I let it sit for about 10 minutes, then as soon as I got the battery reconnected, it started attempting to start again—no idea what's going on.
