Author Topic: HJC-2002 alarm. Not working?  (Read 1672 times)
awdwill
« on: October 25, 2010, 04:09:13 AM »
Just installed HJC-2002 alarm. Not working! please help.
http://www.mwsbike.com/alarm
here's the manual
http://www.mwsbike.com/info/hjc2002.pdf
Connected the following:
Yellow wires to turn signals, one to right, one to left, no problem here.
Red wire to positive terminal of battery, and black wire to negative terminal, no problem here.
Blue wires to the black-and-yellow wire between CDI and ignition coil; I also think I did this right, by cutting the black-and-yellow wire first and attaching one end to one blue wire, and the other end to the other blue wire.
I pressed the 2nd button on the remote for 3 sec and heard a beep, indicating wireless connection being setup between the remote and the alarm. All good here.
The 2nd button (vehicle locator button) works just fine. When I push on it, all four turn signal lights (front and back) will blink simultaneously until I press the same button again. This function (vehicle locator) works perfectly.
However, the most important function (the alarm itself), didn't work. I press the 1st button, and no response from the scooter. Tried again, still no response. Checked the fuses, none blown. Started the scooter, runs well as before.
Anyway, anyone has this system? Please help. Is there something I did wrong? At least the scooter still runs...
