Author Topic: Dining room table full of Kymco body parts.  (Read 378 times)
« on: August 21, 2021, 09:52:01 PM »
Temperature finely dropped from 100F and high humidity to mid 80's and low humidity for one day, next week back up to 100. I started taking all the body panels off the People 200S to touch up the paint and re-dye the black plastic.  So far today I have the black plastic done. I took  it to the kitchen sink and used soft scrub and a scouring pad to make sure I had a clean surface for adhesion. Took it outside to dye it
Went down earlier today to my Kymco dealer and picked up a box of parts I had ordered. Everything came in but the two items I need the most. I replaced both brake levers (bent) and will flush the brake fluid.
Will work on touching up the painted surface and compound the paint tomorrow.
Re: Dining room table full of Kymco body parts.
« Reply #1 on: August 21, 2021, 10:46:00 PM »
Can’t wait to see it when it’s finished!
« Reply #2 on: August 21, 2021, 11:01:28 PM »
Might be a little bit but will chip away at it.  This is one of those scooters the more you dig the more you find. I noticed the headlight lens is cracked and a little cloudy.  Might just try some plastic polish on it.
