Author Topic: Check Engine Light Flashes Intermittently  (Read 3642 times)
Kayemtee
« on: August 26, 2021, 03:14:54 AM »
I’m the original owner of a 2009 Yeger with a little over 10,000 miles.  The check engine light has started flashing.  It never stays on solidly; always flashes on and off if it does anything at all.   Sometimes it stops flashing for a while and then resumes.  The engine otherwise seems to perform flawlessly.  The nearby dealer is backed up for a month for a service appointment.
Two questions: any ideas what might be the cause and does anyone think the engine can be damaged by continuing to run her.
Re: Check Engine Light Flashes Intermittently
« Reply #1 on: August 26, 2021, 10:07:09 AM »
@Kayemtee,
since you have the 176ccm liquid cooled engine in your 200i, I would check all liquids. Oil, coolant, etc.Battery condition? Loose cable? Spray all switches with WD40 or similar.
Then I would check all cabling in my engine compartement for a loose or shabby cable, inclusive spark plug, which could cause such flashing of its "check engine light".
Or is there a "pattern" in flashing?
If there is nothing to find out, front panel off and check of all cabling/ relais there by pulling/twisting.
If there is enough of all liquids, I would not be too concerned about riding further until my workshop appointment.
« Last Edit: August 26, 2021, 10:10:17 AM by Ruffus »
« Reply #2 on: August 28, 2021, 10:59:27 AM »
I agree with all Ruffus suggested PLUS, get to all connectors and apply silicone dielectric grease to all female terminals. The unplugging and then re-plugging with grease may help eliminate this problem.
I had a Yager and it was a GREAT ride!
Louder North
« Reply #3 on: July 31, 2022, 07:10:10 PM »
Count the number of flashes. I believe it is giving you an error code.
2009 Kymco Frost (aka Yager 200i)
10,000 km
bought used in 2018
2007 Aprilia SR50 (Morini motor)
2013 Aprilia SR50 (Piaggio motor)
1986 BMW R80
