Author Topic: Rectifier location  (Read 1233 times)
Adamski
Rectifier location
« on: August 30, 2021, 05:24:48 PM »
Hi. I need to swap out the rectifier on an agility rs50 2t but can't locate it easily. Online manual suggests steering column but it isn't there. Any help appreciated so I don't have to remove all the bodywork!
Regressor
Re: Rectifier location
« Reply #1 on: August 31, 2021, 03:15:57 PM »
I think it is on the steering, (behind the headlight\plastic front cover).
Just remove the front plastic\headlight, should be right behind it next to the horn.
« Reply #2 on: August 31, 2021, 06:14:50 PM »
Follow the yellow wires (or black and green)(or whatever colors) out of the stator and trace them to the first electrical thingy they are connected. That will be the regulator-rectifier.
The stator is usually on the right-hand side of the engine...
Adamski
« Reply #3 on: September 01, 2021, 05:45:54 AM »
Thanks guys. Hoped it was on steering column as less bodywork to remove, but nothing! Will follow the wiring.
martinhedges
« Reply #4 on: September 01, 2021, 08:55:11 AM »
ON my agility 50 is it behind the front bodywork near the horn.  Black unit with fins on it and a white connector with 4 terminals (and 5 wires - 2 wires to one of the connectors).  It is bolted onto a bracket.
