Did you miss your
activation email
Technical | How To
x tovn 250 i engine stalls
Topic: x tovn 250 i engine stalls (Read 361 times)
oceral
Newbie
October 03, 2021, 08:35:48 PM »
hello, the engine stops after a minute, it works irregularly, what is the fault, thank you
the video belongs to me
Re: x tovn 250 i engine stalls
October 04, 2021, 06:44:18 PM »
@oceral,
welcome on board (forum), give pls some more information to this case.
Year, km, history, when does it happen, cold/ warm motor, fuel/filter already changed, last service with CVT tuneup, by whom, as much as possible...
oceral
Newbie
October 04, 2021, 06:51:28 PM »
Hello, first of all, thank you for your interest.
I bought the engine 2020 model new
the engine is cold at the first start, then it stops, the engine is idling irregularly, the engine is servicing at 1785 km, but what do you think could be the malfunction, thank you
Reply #3 on:
October 04, 2021, 07:09:05 PM »
@oceral,
first pls check whether you are still in warranty. IF yes, pls contact your dealer and let them know about this issue. No touching anything within motor compartement if warranty applies.
Since your 250 is an EFI there could be several reasons for stalling
-fuel lines clogged
-fuelpump
-air passage clogged
-sparkplug or ignition cable faulty and thermo-sensitiv
-sparkplug cap simply off...
-one of your switches or cable grounding....
-battery cables loose
-ground cables off or loose
-one fuse or its holder worn out
Pls check as written and give a feedback.
Last Edit: October 04, 2021, 08:11:36 PM by Ruffus
oceral
Newbie
Reply #4 on:
October 04, 2021, 07:20:33 PM »
yes the engine is brand new and under warranty
I gave the necessary information to the service
The service said the idle motor may be faulty.
Reply #5 on:
October 04, 2021, 07:54:45 PM »
@oceral, I'm not familiar with tbe term "idle motor", maybe something within the scoots electronic. Your technicians should read it out with their diagnostic tool. If it's an electronic flaw then its easy to dedect via diagnostic. Could be one of those sensors on the pic.
Pls keep us posted for other readers too.
Last Edit: October 04, 2021, 08:48:56 PM by Ruffus
oceral
Newbie
Reply #6 on:
October 04, 2021, 09:11:14 PM »
ok i will let you know thank you
Back
