Author Topic: Bought a used 2013 kymco UXV 500i… now the check engine light is on...  (Read 1022 times)
RobinsWorld
The check engine light came on when I had it in 4 wheel drive and took it out. How do I reset the check engine light, or how do I find out why it is on? Thanks
souzamoto
Re: Bought a used 2013 kymco UXV 500i… now the check engine light is on...
« Reply #1 on: October 14, 2021, 07:58:05 PM »
Find a dealer with the Kymco Scan Tool
JJJoseph
  • Kymco Sento
« Reply #2 on: October 14, 2021, 10:24:34 PM »
It has to go to a Kymco dealer
« Reply #3 on: October 14, 2021, 11:39:26 PM »
You can reset the code by disconnecting the battery for30 seconds or more. Longer is better since I really don't know but it works! Before you do, just turn the key on but don't start it. Within about 30 seconds the check engine light should flash either a series of short flashes or a long flash followed by short ones. That will be the trouble code.
You may be able to find a list of codes by google search or manualslib.com or on here.
