Did you miss your
activation email
Scooters - 125 to 300
Agility 125
Taking CrankCase off...
Topic: Taking CrankCase off... (Read 1301 times)
ModMan88
Newbie
October 30, 2010, 12:53:10 AM »
I took out all the bolts, but it just wont budge....any ideas on how to get it off?
grazo22
Newbie
Re: Taking CrankCase off...
October 30, 2010, 06:16:43 PM »
There is a ring on the crank which you have to take off, it's a reverse thread c-nut. If you are really sure everything is off then a rubber mallet and some welly is all i can suggest
Scooters are designed to be thrashed, you might as well test the design out
Always on the top speed run ;P
ModMan88
Newbie
October 30, 2010, 10:12:40 PM »
Where is that located? Is it on the kick start?
grazo22
Newbie
Reply #3 on:
November 01, 2010, 07:15:03 PM »
it is on the crank shaft its self, if you put a photo up I will be able to help more as I have done this procedure many times.
ModMan88
Newbie
Reply #4 on:
November 05, 2010, 10:40:32 PM »
I got the case off. Just took a rubber mallet and a paint chisel and on the top right corner just tapped it and it spaced a little bit and then it just pulled off.
Back
