Author Topic: Battery light remains on. 2012 kymco people gt 200i  (Read 1030 times)
Garym0510
« on: October 20, 2021, 06:11:43 PM »
Just bought with 8000miles the battery light came on when I test road it. So today when I purchased it I bought a new battery slapped it in battery light remained on. I rode it from pick up location stopped numerous places on the way home. No problem starting at all. I know thus has been talked about before I don't have a volt meter at moment to check things.
Whats the opinions,
Stator going out?
Loose connection
Or should I try resetting the thing by holding the throttle open clearing the faults?
Re: Battery light remains on. 2012 kymco people gt 200i
« Reply #1 on: October 20, 2021, 07:07:10 PM »
@Garym0510, hard to say without having any facts of voltage showing. Need not to be your generator. Long shot.
 Don't think resetting would do the trick, but try anyway.
Think you mentioned a shop who would do a tune-up on your scoot, they should have a look into this issue when you're there.
« Reply #2 on: October 20, 2021, 09:17:36 PM »
I'd start by checking the battery with a multimeter (if you don't have one, go buy one, they are a handy tool to have..inexpensive). Check with scooter off...you want around 12.7 volts from battery...and check with it running and revving...forget the exact number you're looking for but something around 14 or 14.5 while revving?
Make sure all battery cable connections are tight..
Garym0510
« Reply #3 on: October 23, 2021, 02:38:34 AM »
Eh I just bought a rectifier, gonna slap it in tonight and see if it solved the problem and with the bike being about 20 miles away from 8,000 it's probably time for one and since they are pretty common culprits. If it doesn't solve the problem then I will get volt meter and go that route and atleast I'll have a new rectifier lol.
« Reply #4 on: October 23, 2021, 09:22:57 AM »
@Garym, maybe its worth to follow a troubleshooting schedule as for example "manualslib" has, before changing parts by random. (pls see pics)
Garym0510
« Reply #5 on: October 23, 2021, 02:00:31 PM »
Probably a good idea Rufus, I changed the rectifier last night and it's still on so there's that. But it's weird it starts right up no lights are dim and I rode it home from work at night perfectly fine.
Garym0510
« Reply #6 on: October 23, 2021, 02:03:10 PM »
Oh forgot to mention battery is brand new and I had the old battery tested the one where the light originally came on and it tested goof as well.
« Reply #7 on: October 23, 2021, 08:57:34 PM »
@Garym, one try.
-take both battery cables off your battery.
-hold those two (now currentless) cables together for one (1) minute, then all of your transistors within your ECU should be without voltage and resetted. Maybe ...
Are you 100 % sure having the right rectifier, for there are several around. Not all of them communicate with your generator. All connectors really tight and not loosing a prong ...
« Last Edit: October 24, 2021, 09:09:09 AM by Ruffus »
Garym0510
« Reply #8 on: October 24, 2021, 12:00:40 AM »
@rufus thanks I'll try that because the hold the throttle for 10 seconds didn't work so...
Garym0510
« Reply #9 on: October 24, 2021, 01:17:47 PM »
@rufus nope didn't work, rode into work and hooked up the battery tender this morning it's charging at 1amp gonna let it charge for the next twelve hrs then probably ride to the shop tomorrow...
« Reply #10 on: October 24, 2021, 06:59:52 PM »
Sorry, distant I'm at end of my guesswork.
« Reply #11 on: October 24, 2021, 07:17:32 PM »
late to the party,
sounds like a short too me, check connections make sure they are clean and dry first, then apply dielectric grease and reconnect
fwiw, I get my chemicals from https://caig.com/
Garym0510
« Reply #12 on: October 24, 2021, 10:33:55 PM »
Yeah i got the right rectifier, had to manually select it from the website like putting in my scooter type year and all and looks exact same to the original bought from electrosport.com. I will check connections tomorrow buying multi meter tonight..
Garym0510
« Reply #13 on: October 24, 2021, 10:35:48 PM »
Oh yeah and the battery only charged for maybe 10 minutes this morning before being fully charged so its not draining much what ever it is. maybe a loose connection is all it is after all?
« Reply #14 on: October 25, 2021, 11:12:59 AM »
@Garym, your dashboard has to "know" somehow, to switch its charging light on.
So, as already stated all around, a short, a loose cable, simply a malefunction appears.
Having your multimeter, next steps to check would be
-battery voltage (motor off)
WRITE EVERY STEP DOWN
-battery voltage during starting
-delivered voltage from generator to battery
-lights on during running, voltage?
It has to be found out where the "leak" is located at.
