Author Topic: The Bottom of My Carb?  (Read 537 times)
Togger
« on: October 31, 2021, 08:31:40 PM »
Finally got the carb out but what a hassle. There are a couple if electrical connections on the bottom I don't see talked about in videos. One has a flat connecter that plugs in, and then right next to it is a silver electrode with a wire that connects to it. Anyone know what they are?
Re: The Bottom of My Carb?
« Reply #1 on: October 31, 2021, 09:12:35 PM »
If those two plugs are on a small item which is removeable by a 8mm bolt, than is a carb heating installed.
If those two plugs are on a black roundish plastic part, then it's the carbs throttle potentiometer.
« Reply #2 on: October 31, 2021, 09:14:33 PM »
any chance you can post a pic? Mine has 2 connections, the by-starter (electric choke) and the throttle position sensor...not sure what other connections there would be...
Togger
« Reply #3 on: October 31, 2021, 10:37:34 PM »
Those are both up high on the side. I had to unscrew both because I can't get to the connector plugs. I'm talking about 2 connections at the very underside of the carb.
« Reply #4 on: November 01, 2021, 10:20:19 AM »
@hawk, there are at least three different types of carb used in our KYMCOs.(what I saw until now)
- all are CVTs (constant velocity type/diphragm type)
- one with only electric bystarter
- one with electric bystarter and heat element
(middle pic, white and green cable fown there)
- one with electric bystarter and throttle body potio
(poti LH side down, socket upwards)
All three of them work fine with the right jets, though I didn't figure out what for this throttle body potenziometer should be good for.
Tell me what you think of...?
« Last Edit: November 01, 2021, 10:30:45 AM by Ruffus »
« Reply #5 on: November 01, 2021, 12:54:42 PM »
interesting..that's the first I've seen of a Kymco carb with a heating element. (my Helix carb has an odd way to heat the carb..a coolant line runs to it to provide additional heat)
Togger - are you able to take a pic and upload it?
