Author Topic: Brighter Headlight Options  (Read 1646 times)
Monoplex
« on: November 02, 2010, 01:10:13 AM »
I'd like to get more front end illumination. Has anyone tried a brighter bulb, driving lights, or an HID kit? I'm sure that power draw is an issue but I'm open to suggestions.
Thanks for your time!
lankeeyankee
  • I have an attitude problem with stupidity
Re: Brighter Headlight Options
« Reply #1 on: November 05, 2010, 12:08:10 AM »
This was recently discussed. cant find the link but if you search headlight I am sure you find info your looking for unless someone repeats there opinion here.
lifeisabeach
« Reply #2 on: August 04, 2012, 01:39:30 PM »
I've installed the HID in the people 250, which shares the same housing.  Although the light casted is much brighter in comparison, the reflector used in the kymco is total garbage and makes a terrible beam pattern (which is just less noticeable with the weaker halogen h4)
I went and put a sylvania silver star in, and it improved the function a bit after I got sick of the HID.
If you do go HID  stay in the low range like 4000k, and get the bixenon kit bulb and harness, so you can retain your hi/lo function
