Did you miss your
activation email
Scooters - 50cc
Like 50 2T
Installing 19mm carb on 2013 kymco like 70cc
Topic: Installing 19mm carb on 2013 kymco like 70cc (Read 1684 times)
hollywoodxxx
Newbie
December 31, 2021, 06:50:30 PM »
what type of intake do I go with obviously
The stock one would be to small on engine side as well
as the carb side so what do I need a were
to order from ?
dan v.
Full Member
Re: Installing 19mm carb on 2013 kymco like 70cc
January 01, 2022, 12:41:50 AM »
You will be fine with the stock intake.
Grand Rapids, MI
hollywoodxxx
Newbie
January 01, 2022, 03:11:31 AM »
isn't the space between the two bolt hole's on manifold wider at engine side and carb side with
the 19mm ?
Back
