Author Topic: Power Steering Kymco MXU 700i EPS problem  (Read 1779 times)
zenekquad
« on: January 18, 2022, 01:11:37 PM »
Hi,
I have a problem with a power steering. It doesn't work, EPS control led is flush, and power steering not work. During driving it try to turn right side. Please for help....
Re: Power Steering Kymco MXU 700i EPS problem
« Reply #1 on: January 18, 2022, 09:39:26 PM »
1. Fuse?
2. Still in warranty?
airshot
« Reply #2 on: January 18, 2022, 10:46:45 PM »
Something I have heard numerous complaints about.  I opted to stay away from the power steering with the issues they are having with them.  Even the ones that work well have issues at higher speeds, the only real advantage is at slow speed in 4wd mode.  You might look into other mfgr forums and see what others are finding...  With it pulling to the right, sounds like it might be an issue with the PS unit itself.  Time to find a dealer??
zenekquad
« Reply #3 on: January 19, 2022, 06:52:52 AM »
Fuse is ok, Kymco after warranty....
« Reply #4 on: January 19, 2022, 12:59:51 PM »
OK, then check motor ground and connector.
airshot
« Reply #5 on: January 19, 2022, 02:55:41 PM »
If you cant find a solution here, try looking for similiar issues on Polaris, Yamaha, and other makers machines by going to their forum sites and do some searches.  The PS systems are all similiar, so with every mfgr having some issues, you might find some usefull information.  Please let us know if you  find anything..
