Did you miss your
activation email
Scooters - 125 to 300
Agility 125
Rear indicator changes
Topic: Rear indicator changes (Read 899 times)
Footsoldier2008
Newbie
January 22, 2022, 04:51:32 PM »
Has anyone changed out the standard bulb holders for led ones if so what size thread?
Eastern Iowa, USA
Re: Rear indicator changes
January 22, 2022, 05:47:56 PM »
if you're going to add led turn signal bulbs you'll need to change your flasher relay to an led flasher relay.
Not positive about yours but on my scoot the rear bulbs are BAU15S. They don't have threads but rather pins on the bulb socket. You need to make sure the pins on your existing bulb match up with the pin placement on your new bulbs.
aschrauth
Sr. Member
Have patience, Don't be in such a Hurry.
February 08, 2022, 04:14:29 AM »
I haave converted mine, You will need an LED flasher relay and a resistor to splice into the turn signal bulb on the instrument cluster, Without this resistor the turn signals will act as 4 way hazards.
Kymco 125cc
Wolf Rx50 BBK 80cc
Back
