Author Topic: lithium ion battery vs AGM  (Read 2281 times)
airshot
Re: lithium ion battery vs AGM
« Reply #15 on: February 10, 2022, 09:42:43 PM »
I was having the typical power drain issues with my new AK550 so i tried a lithium and im EXTREMELY impressed so far. Cant say anything about it.
Under proper circumstances they are great, just follow instructions to the letter !   They are safe if properly handled, but unforgiving if you make a mistake.  In a scooter that is normally not used in cold weather should be good. Just dont use a standard battery charger....follow instructions!!
wymple
« Reply #16 on: February 18, 2022, 03:50:50 AM »
Yesterday I installed a 12v, 14 amp battery in my 500. It has 240 CCA. I always go with AGM in my bikes. I have no idea how old the previous lead acid battery was, but it had 12 amps, 220 CCA.
  • Central Iowa
« Reply #17 on: February 18, 2022, 04:07:17 AM »
What brand/model battery did you use?
When I looked today in the electrical diagrams for my AK 550 the info there showed a 14 Ah battery yet the battery that all AK 550 scoots that I know about come from the factory with a 11.8 Ah battery at best... Kymco branded Yuasa TTZ14S.
aschrauth
« Reply #18 on: February 18, 2022, 04:28:07 AM »
I too am curious, Only batteries that I can find on Amazon are 12v6A with less than 100CCA.  Unfortunatly for me batteries that I install dont last more than three months because of all of the short trips that I take, Eventually the load that occors when I start my scooter ends up wearing them out even though the charging system works perfectly. Weather here in Missouri doesnt help either.
Kymco 125cc
Wolf Rx50 BBK 80cc
wymple
« Reply #19 on: February 18, 2022, 11:57:31 PM »
https://www.ebay.com/itm/154082753955
Biggest thing I could find that would physically fit.
« Last Edit: February 18, 2022, 11:59:04 PM by wymple »
« Reply #20 on: February 19, 2022, 01:54:49 AM »
Yeah, just  a matter of measuring the stock battery, and the battery box to see if a larger battery will fit with minimal alterations.
I found that if I cut 5mm off of my battery box hold-down posts on the lid...I could fit a 14Ah Yuasa where my LIKE200I's 8Ah battery had sat.
JJJoseph
  • Kymco Sento
« Reply #21 on: March 02, 2022, 10:05:07 PM »
Is there room in the battery box to drop in a sealed 8, 10 or 12 Ah battery! More Ah, the better. I have a 14 Ah in my LIKE200I,  replacing the stock 8 Ah.
Yuasa charts show dimensions available.
Good question! Some models have a battery box with little room to spare.  Like carpenters always say,"Measure twice, cut once"!
airshot
« Reply #22 on: March 03, 2022, 01:05:45 AM »
I was having the typical power drain issues with my new AK550 so i tried a lithium and im EXTREMELY impressed so far. Cant say anything negative about it.
Yes they are great as long as your carefull.  Do not jump a regular battery to your lipo and make sure you have a proper charger. I have used them for many years in my radio control hobby and they are awesome....just be carefull and dont make a mistake !!
jermwars
« Reply #23 on: March 03, 2022, 09:45:05 PM »
Ok, show of hands what type of battery do you run in your scooter. Agm or lithium? Being someone who only works three miles from his home I find it difficult to maintain AGM batteries. No matter how much I maintain them the load they produce is very difficult to start my scooter (Granted I use a 12v6A battery) would it be worth it to purchace a lithium battery and get more life out of it compared to purchacing an AGM? Just curious.
This is the brand that I use
https://www.lowes.com/pd/Mighty-Max-Battery-YTX7A-BS-Battery-for-Motorcycle-Powersports-Scooter/5000177971?cm_mmc=shp-_-c-_-prd-_-hdw-_-ggl-_-PLA_HDW_214_Auto-Batteries-_-5000177971-_-online-_-0-_-0&ds_rl=1286981&gclid=EAIaIQobChMIwMHe_oPM9QIVdfHjBx1_BgpnEAQYASABEgLvDfD_BwE&gclsrc=aw.ds
REALLY impressed with this bad boy...looks like its on sale too...$35 off what i paid. That pisses me off for some reason :D
https://www.amazon.com/NOCO-NLP14-Powersport-Motorcycles-Snowmobiles/dp/B091P9QXX7/ref=sr_1_1?crid=2RMBYTOS8ETK0&keywords=lithium+motorcycle+battery&qid=1646343820&sprefix=lithium+moto%2Caps%2C374&sr=8-1
« Last Edit: March 03, 2022, 09:46:58 PM by jermwars »
22' KymCo AK550
07' Yamaha Majesty YP400
