Author Topic: Advice on engine  (Read 1456 times)
jans
Advice on engine
« on: February 17, 2022, 09:54:07 AM »
I am wondering whether this can be right or not? Is there a passage between the crankhousing and the insert hole for oil pump? When I overflood the crankhousing with petrol, the hole for the oil pump get flooded as well... is that normal?
I am working on a ZX from 2009
thanks
Pellepan
Re: Advice on engine
« Reply #1 on: November 18, 2022, 06:31:53 AM »
Should be normal (as far as I know), it has a O-ring to keep it close from leaking.
Same construction as Honda Dio, see video here:
https://youtu.be/_ut9SNEMlxE?t=49
