Author Topic: UXV 700 stalls after engine breaking downhill  (Read 1191 times)
ozhills
« on: February 27, 2022, 09:50:18 PM »
When I go down a steepish hill without applying the throttle, it usually stalls towards the bottom when I'm about the apply the throttle again.
Sometimes the engine is very rough (if it hasn't stalled).
Why would it do this, and can it be fixed?  thanks.
Bratman2
Re: UXV 700 stalls after engine breaking downhill
« Reply #1 on: March 01, 2022, 09:51:15 PM »
Sparkplug!
2019 UXV 700i LE Hunter
2014 MXU 450i
2004 Mongoose 90 (grandson's)
2010 Grizzly 450
ozhills
« Reply #2 on: March 07, 2022, 09:48:34 PM »
Took it in for first service, the dealer said this issue made no sense mechanically, and he'd check with the distributor to see whether a sensor might be to blame.  My next step will be to take a couple of videos to show him.
Bratman2
« Reply #3 on: March 08, 2022, 02:19:46 AM »
I still would change the spark plug. They are bad about fouling the plug. Especially if a newer model.
2014 MXU 450i
2010 Grizzly 450
airshot
« Reply #4 on: March 08, 2022, 10:09:39 PM »
Unfortunately they all say that when they have no clue!! He needscto hook up a trouble shooting device and ride it until it acts up.  They always run fine when sitting in the shop.......
TomFIV
  • 2017 700i
« Reply #5 on: March 20, 2022, 08:15:16 PM »
How many miles are on it? Mine did the same thing during the first 300 miles. I am at about 500 and I has only done it once since 300ish miles.
ground hound
« Reply #6 on: April 01, 2022, 12:30:30 AM »
Yes I did and may not any more have a stall problem also on my 2020 700i. I notice it more when plowing, it would stall out between stoping and changing gears. It would only randomly do it. The 1st service I told my dealer but of course it wouldn't do it for them. They told me they are set up lean at the factory. I said O, does that make it ok?  So after my 1st year went by I got frustrated and put a tuner in it since my warranty was up.  That messed it up even more with it stalling , running rough, fowled plug. So then I took the turner off and called a different  dealer for help. They told me to raise the idle slightly and it seems to be much better now.  It's been 2 weeks with out stalling. I raised idle to 2k.
