Author Topic: uxv700i engine oil /cvt  (Read 1533 times)
uxv450uxv700
« on: April 12, 2022, 12:35:30 AM »
 I warmed my 2021 uxv700 up to change engine oil. new HF147 filter in hand. My question is, Does the engine and cvt share the same oil ?  I looked in my manual. it has a lot to be desired. very lacking in information. it talks about engine oil, front and rear differential oil, but no mention on cvt.
Bratman2
Re: uxv700i engine oil /cvt
« Reply #1 on: April 12, 2022, 01:02:31 PM »
The engine and the wet clutch share the same oil. The CVT sheaves are outside the engine/transmission block. The clutch is mounted on the shaft of the rear CVT sheaves inside the engine/transmission case. You want to make sure not to use an energy conserving oil or you may get clutch slippage. I use Mobil 0W-40. You could use Rotella 5W-40 if you wanted to. Or motorcycle oil!
2019 UXV 700i LE Hunter
2014 MXU 450i
2004 Mongoose 90 (grandson's)
2010 Grizzly 450
souzamoto
« Reply #2 on: April 12, 2022, 03:38:20 PM »
If you have Oil in the CVT you have a big problem. No, No oil goes in the CVT.
airshot
« Reply #3 on: April 12, 2022, 04:45:27 PM »
Great information here....what ever oil you choose, be sure it is wet clutch compatible !!  Using an ATV rated oil will assure it is wet clutch compatible.
uxv450uxv700
« Reply #4 on: April 13, 2022, 02:33:41 AM »
I used a motorcycle oil 10w40 . it didn't say anything about wet clutch compatible. hopefully I'm ok ?
airshot
« Reply #5 on: April 13, 2022, 04:42:07 PM »
Not familiar with motorcycle oils but I believe most are.  You not going to hurt anything by using oil not designed for wet clutches, however, long term use could cause the clutch to slip.
