Author Topic: Aftermarket Parts  (Read 878 times)
agilebda
Aftermarket Parts
« on: May 27, 2022, 10:31:04 AM »
Re: Aftermarket Parts
« Reply #1 on: May 27, 2022, 12:38:56 PM »
For the starter motor I would go for this AMAZON  offer. If it dies prematurely, okay, no real harm done, except 1/2 an hour of your time to replace.
As for the belt I might rather stick to BANDO or OEM material, for reasons of possible CVT and clutch destruction.
« Reply #2 on: May 27, 2022, 05:54:52 PM »
I agree with Ruffus on this. Besides, the belt length is incorrect as it should be 1004 mm not 1030 mm.
agilebda
« Reply #3 on: June 10, 2022, 01:04:41 PM »
Thanks guys,
Yeah a little skeptical about the belt for sure. It's amazing how the price is through the roof with the OEM belts.
« Reply #4 on: June 10, 2022, 02:07:43 PM »
Curious...
How old is your scooter?
How often have you replaced the belt?
agilebda
« Reply #5 on: June 10, 2022, 02:35:40 PM »
She is 10 yrs old. Replaced the belt 3 times. (preventative maintenance) odo reads 38,000
« Reply #6 on: June 10, 2022, 04:09:05 PM »
The thing about Amazon is a great and easy return system. You ( or I ) could try that belt and if the length turned out to be a typo (1003 mm instead of 1030 mm) it might be a good item. You could direct compare if you had a spare genuine belt.
