Author Topic: Starter dragging issue  (Read 1119 times)
Rickster
« on: June 03, 2022, 02:16:14 PM »
The starter on my 2010 Yager 200i labors when cranking the engine. I've cleaned and checked all wiring connections. Any other ideas of the cause? Thx.
2007 B&W 150
2010 Yager 200i
Re: Starter dragging issue
« Reply #1 on: June 03, 2022, 02:25:33 PM »
Battery?
« Reply #2 on: June 03, 2022, 03:01:54 PM »
@Rickster, like Stig says, first suspect might be the battery....
But maybe check this out too
https://www.kymcoforum.com/index.php?topic=31637.0
« Reply #3 on: June 03, 2022, 03:05:31 PM »
Battery?
that's the first place I'd look!
Rickster
« Reply #4 on: June 03, 2022, 04:59:48 PM »
I neglected to mention that the battery is new and tests good. Also tried another known good battery with the same results.
Ruffus, I will try the suggested fix with the grounding cable this weekend. Great investigative work!
Cheers!
2007 B&W 150
2010 Yager 200i
« Reply #5 on: June 03, 2022, 09:02:47 PM »
@Rickster, also check fuses, particularely their cabling beneath, there are some hidden corrosion nests.
Best you begin your probe with jumpstarting directely on your starter motor,
shows you whether it's faulty or not, then start relais, start switch on your handlebar and so on...
