Author Topic: 2016 UXV 500i fault code P1110  (Read 1204 times)
2016UXV500i
« on: June 07, 2022, 04:01:19 PM »
Looking for some help with what a fault code P1110 is on a 2016 UXV 500i. Will start the shutoff and that is the code that is displayed. Happens randomly then goes away.
souzamoto
Re: 2016 UXV 500i fault code P1110
« Reply #1 on: June 08, 2022, 04:17:58 PM »
I don't see a P1110 code listed. You sure it's not P0110?
This list was lifted from the Kymco Service manual
Blinks   Failure Codes   Fault description   Priority   Fault management
1   P0217   Engine temperature overheat   1   1.Stop immediately and check CELP code.
2. Check if the engine temperature sensor or electric circuit is faulty.
3. Check engine lubrication and cooling systems.
4. Check engine ignition and fuel systems.
2   P0335   Crankshaft position sensor or circuit malfunction   2   1. Check if the crankshaft position sensor, its connector, or wiring is faulty.
2. Make sure the generator rotor is aligned with the crankshaft position sensor.
3   P1120   Throttle position sensor setting value problem   2   1.Check if the TPS connector or wiring is faulty.
2.Check if the TPS is adjusted.
4   P1121   Throttle position sensor output range problem   2   1. Make sure the TPS connector is connected correctly.
2. Inspect the TPS
5   P1122   Throttle position sensor movement speed problem   2   1. Make sure the TPS connector is connected correctly.
2. Inspect the TPS
6   P0560   Battery voltage malfunction   1   1. Check the battery voltage.
2. Inspect the charging system.
7   P0110   Intake air temperature circuit malfunction   2   Inspect the T-MAP sensor
8   P0410   Idle air valve circuit malfunction   2   1. Check if the ISC connector or wiring is faulty.
2. Check the resistance of the idle air valve.
9   P0505   Idle speed volume control range problem   3   1.Check the ISC steps range with the diagnostic tool.
2. Check throttle body for carbon deposits.
3. Check intake for air leaks
10   P0251   Injector or electric circuit problem   2   1. Make sure the fuel injector connector is connected correctly.
2. Check if the ECU sends a signal to the injector.
3. Check the power source and resistance of the injector.
4. Make sure the battery is fully charged and connected correctly.
11   P0350   Ignition coil or electric circuit malfunction   2   1. Make sure the ignition coil connector is connected correctly.
2. Check if the ECU sends a signal to the ignition coil.
3. Check the ignition coil power source and resistance.
12   P0230   Fuel pump relay or electric circuit malfunction   2   1. Make sure the relay and pump connectors are connected correctly.
2. Check if the ECU sends a signal to relay.
3. Check the fuel pump relay resistance
13   P0219   Engine speed has exceeded top speed   2   Check if the CVT belt is broken.
14   P1560   Sensor doesn’t receive power source from ECU   2   1. ECU output to each sensor should be 5 DCV.
2. Check if the power source for all sensors is 5 DCV.
3. Check for a problem in the wiring harness.
4. If the CELP still blinks replace the ECU with a new item even if the output power source of ECU is normal.
15   P0700   Engine starting speed exceed CVT speed limited   2   Not used.
16   P0115   Engine temperature sensor or electric circuit malfunction   2   1. Make sure the WTS connector is connected correctly.
2. Check if the ECU pin is broken.
3. Check if the resistance of the sensor is out of specification.
17   P1561   Temperature gauge electric circuit malfunction   2   Not used.
18   P0650   CELP electric circuit malfunction   3   1. Check if the CELP bulb is faulty.
2. Check the CELP wires for damage.
21   P0105   Atmospheric Pressure Sensor/Circuit Malfunction   2   1. Make sure the MAP sensor connector is connected correctly.
3. Check the sensor voltage.
4. Use Diagnostic Tool to check the pressure.
22   P0110   Roll sensor or electric circuit malfunction   2   1. Make sure the sensor is installed in the correct position.
2. Check the sensor voltage.
3. Check if the ECU pin is broken.
2016UXV500i
« Reply #2 on: June 08, 2022, 07:28:26 PM »
Almost positive it was a P1110. I noticed in the list you sent me P0110 is listed twice. I think it may be a misprint and the 22 blink may be a P1110. Not sure why they would use the same code twice.
« Reply #3 on: June 08, 2022, 08:51:28 PM »
Items 7 and 22 list P0110 first in#7 intake pressure then #22 for roll sensor. Like souzamoto said there is no P1110.
When the CELP (check engine light) blinks, it will blink seven short flashes for, let's say P0110. It will not blink any code flashes for the actual fault code. If #22 there would be two long flashes and the two short flashes.
How did you first determine code P1110 in the first place? With no service manual?
« Last Edit: June 08, 2022, 08:55:27 PM by CROSSBOLT »
Maxxer450
« Reply #4 on: January 24, 2023, 03:18:36 PM »
I'm a little late on this topic but the P1110 code just came up on my atv.  I was tracing out a wiring problem and had not reconnected the rollover sensor.  Plugged it back in and code went away.
Maxxer450
« Reply #5 on: January 24, 2023, 03:35:06 PM »
I should have mentioned I have a service manual however the actual 'P1110' was on the bottom right of the display so no need to count CELP flashes.
