Did you miss your
activation email
Scooters - 125 to 300
People GT 300i
Brake Disc Thickness
Topic: Brake Disc Thickness (Read 784 times)
agilebda
Sr. Member
June 10, 2022, 01:06:57 PM »
Hi guys,
At what stage would you say to replace the actual disc on my rear wheel? Brake pads wore thin and I didn't realize til I heard the dreaded scrape/friction noise.
Re: Brake Disc Thickness
June 10, 2022, 02:04:55 PM »
The service manual will specify the service (thickness) limits of your brake disc......assuming the disc was not damaged by the worn brake pad.
June 10, 2022, 09:02:15 PM »
@agilebda, brake discs minimal thickness is written / etched on the disc.
Should grooves deeper than 0.5mm appear, disc has to be changed.
agilebda
Sr. Member
Reply #3 on:
June 17, 2022, 04:41:20 PM »
Thanks for all the replies. Looks like I got away clean. Just about anyway. Another week of riding, I would have had to replace disc for sure.
Back
