Author Topic: valve clearance inches vs MM and oil in filter  (Read 1694 times)
william1313
« on: June 13, 2022, 04:00:33 PM »
I have a Kymco Peoples 50 cc 4T.   Got it around 2009
Live on an Island and I did not do much maintanence until last week when I decided to do it myself.
Watched tons of videos
The topic of valve clearance was very interesting.
Many talk about using .004 inches for the clearance.
The manual, of course is in MM an recommends .04 mm
Attempt #1 I used the .004 inches.   BTW the bike ran quite good before I attempted to fix it.
.004 inches caused very loud tapping.  I feared I was actually damaging something it was so loud.
Next I went t the Manual suggestion of .04 mm and it hums like a bird.    So with the  Peoples 50 cc 4T I highly recomment you use .04 mm.  If you are stuck on inches then .00158 inches.   There is quite a difference between .004 inches and .00158 right?  Its 2-3 x the proper gap size.
As an aside I changed the oil, trans fluid, and inspected the filter which had some oil on it.   I could use some good common sense approach to that.
Re: valve clearance inches vs MM and oil in filter
« Reply #1 on: June 13, 2022, 06:01:36 PM »
The Kymco standard for most 4 cycle engines is .1 mm/.004" from 50 to 300 cc.
.04 mm is generally a book typo error because it is way too small. You probably had the cam in the wrong position when setting .004" because that is generally quiet even on air cooled engines.
« Reply #2 on: June 13, 2022, 08:59:04 PM »
Here in Italy we adjust
-intake valve 0.10 mm
-exhaust valve 0.12 mm
Too tight, heats up.
Too loose , starting problems, noisy
« Last Edit: June 13, 2022, 09:01:09 PM by Ruffus »
« Reply #3 on: June 13, 2022, 09:21:41 PM »
That will work well but not .04 mm!
« Reply #4 on: June 13, 2022, 09:59:53 PM »
Piaggio manual says .08mm for all 3 valves of my LIBERTY150.
I do +.08mm > -.10mm.
I tell a lie - .08 makes me nervous :) so I do .10mm.
Yeah - going to be nice and quiet at .04mm.....until!
My 'tell' is - do I have a little up/down movement on the rocker arm adjuster screws? If they both aren't moving even a fraction - I need to re-do TDC because I may not be there!
« Last Edit: June 13, 2022, 10:07:58 PM by Stig / Major Tom »
william1313
« Reply #5 on: June 13, 2022, 10:27:15 PM »
Thank you for your amazingly fast reply.
I suppose it could a typo.  However .04 mm was used more than once in the Manual.
see chapter 3.
https://absolutelyscooters.net/manuals/Kymco_People_S_50_125_200_Service_Manual.pdf
I am pretty sure I had the cam in the right place because I was so paranoid I would make a mistake I triple checked it.
The .04 mm feeler felt like aluminum foil so I did question this.
There are several references in the literature for using .04 mm or near equivalents for example
(see 3.10 minutes into the 6 min video)
see post by tortoise
https://scootdawg.proboards.com/post/229665
https://scootdawg.proboards.com/post/439154
However to your point,  I see several posts saying just what you said.
Very confusing
Bill
« Reply #6 on: June 13, 2022, 11:30:10 PM »
see chapter 3.
Very confusing
Bill
This is from manualslib.com on the People S 50, 150, 200:
https://www.manualslib.com/manual/982143/Kymco-People-S-125.html?page=79#manual
william1313
« Reply #7 on: June 14, 2022, 01:06:46 AM »
Read page 41 same manual.
There must be some logical explanation.
https://www.manualslib.com/manual/982143/Kymco-People-S-125.html?page=41#manual
« Reply #8 on: June 14, 2022, 01:21:01 AM »
Chinglish......as .004 becomes .04mm.....typo for metric proofreader program in the printer??
« Reply #9 on: June 14, 2022, 01:22:00 AM »
Been there, seen that, that and other models starting in 2006 or so. Many errors in operator and service manuals. Trust me! .04 mm = .0016" and a valve stem up to operating temp will "grow" that much. .1 mm/.004" is your target.
Several here tried over the years to get corrections made but were ignored. What could we know? Har, har! Some outfit horned in to write and correct but were largely ineffective.
The biggie early on was octane rating of fuel. Other countries don't have our (R + M)/2 rating system. The book said 91 minimum and the sticker inside the tub under the seat said 87 (R + M)/2.
Kymco is great scoots. Well designed, well made. Their books suck with errors and the importer is in chaos. You will hardly ever need parts and they nearly can't be killed.
william1313
« Reply #10 on: June 14, 2022, 01:29:08 AM »
ok i will try .1 mm again
here is another post quoting a man who did just that and got loud tapping like I did.
https://www.kymcoforum.com/index.php?topic=6172.0
If I do it and get the loud tapping should I just ignore?
« Reply #11 on: June 14, 2022, 07:43:24 AM »
Absolutely not! Like I said before, loud tapping usually means the cam is in the wrong position when setting the clearance. Just because the "T" is in the window does NOT mean the cam is right for setting valve clearance.
william1313
« Reply #12 on: June 14, 2022, 04:58:00 PM »
so I did 4 thinks to assure I was in dead center
1. aligned the T
2  made sure the arms were movable
3.  made sure the large hole was set equal between valves
4.  made sure the small holes were in line with the case on both sides
Was there anything that I might have missed.   Could the tapping be because the clearance was too large?
« Reply #13 on: June 14, 2022, 05:15:07 PM »
1. aligned the T
That confirms you have it in the right position. Could you do a video or just audio and post it here for us .... to hear?
william1313
« Reply #14 on: June 14, 2022, 05:59:37 PM »
I think one of the biggest annoyances on forums is trying to help people who do not listen or refuse to get it!
I am not one of those people.   But as I find myself continuing to challange the ideas that I am hearing I hope I do not come across as dumb or worse ungrateful.    With that being said:
I scrutinized the 50,125,200 peoples manual again
On section 3-5 it states this.
Valve Clearance   IN:  .12mm , 50 cc .04 mm
                          EX   .12 mm, 50 cc .04 mm
clearly the author of the text is trying to differentiate the 125 and 200 cc verson of the peoples 50 from the 50 cc model.
I do understand the theory of typos but it would be hard to make a typo in this situation.
Given all this:  I also understand the point that when the engine heat up it will expand by .04 mm and make a zero clearence which of course is not good.   Please be patient with me and take a second to look at this "page 3-5"  I am referring to and let me know if you are still 1000% sure its a typo.   because it means a lot more work for me if it is.
apologies if I am wasting time and thanks for all your help
