Author Topic: No power in top gear - 35 MPH top speed vs 55 MPH - K-pipe 125cc  (Read 1224 times)
makeway
My Kymco Kpipe has lost a lot of its power. It maxes out around 35 mph instead of the 50-55 it used to get. It actually maxes out in 3rd gear for the most part, and when I change to 4th gear don't get much more speed at all.
I've cleaned /rebuilt the carbs, and cleaned the air filter.
Any suggestions as to what to check next?
It starts right up, and I have it idling around 1.5k
Re: No power in top gear - 35 MPH top speed vs 55 MPH - K-pipe 125cc
« Reply #1 on: June 27, 2022, 04:21:00 PM »
Doesn't sound like the valves need adjusting - since it starts right up.
But what are your miles - and when was the last time they were checked?
makeway
« Reply #2 on: June 27, 2022, 04:50:14 PM »
It only has around 800 miles. I'm not sure if the previous owner ever checked them or not.
I can add that to my to do list.
I'm going to check it's compression tonight too, does anyone know what the compression should be?
« Reply #3 on: June 27, 2022, 07:03:16 PM »
how quickly did the power loss happen ?
mine had power loss just within a few miles,  I learned after my motor wouldn't even start, that air cooling isn't enough, you should really add an oil cooler,  these things overheat and eat oil.
makeway
« Reply #4 on: June 27, 2022, 07:46:47 PM »
It pretty much never has the power. Yes it does seem a little weaker after a 20 minute ride. But even when I first start it up it tops out around 35 MPH
« Reply #5 on: June 27, 2022, 07:51:09 PM »
Sounds like you might describing a soft seize,?
After it cools, does it run better?
I'm not thinking any new air-cooled vehicle should require an oil cooler?
« Reply #6 on: June 27, 2022, 08:02:54 PM »
nothing new about the k-pipe motor, its 70 year old technology, when you buy an aftermarket replacement motor, it comes with an oil cooler
makeway
« Reply #7 on: June 27, 2022, 08:54:50 PM »
After it cools it tops out at maybe 37 mph instead of the 35 mph.
« Reply #8 on: June 27, 2022, 09:17:16 PM »
when I bought mine used with barely 3000 miles, I was told it had already had the top end done. I put another 800 on it before it was unbuttered toast (where did the oil go?) That is when I decided to replace the whole motor, I was looking for a 140cc, cause it would be an easy swap, I ended up with a 190cc 5 spd. still an easy swap, but required a custom exhaust, now I'm just shifting from 4th to 5th at 55,  I still ride at the same speeds 40-50 on the roads I travel, just shift a lot less
wymple
« Reply #9 on: June 28, 2022, 04:53:21 AM »
Take it to a dealer. A bike struggling that bad has a serious issue with timing or fuel & something is not right.
leomagnus
  • Providence, RI
« Reply #10 on: June 28, 2022, 06:39:51 PM »
This might sound like a strange idea, but in italy when you by scooters/bikes, they put a washer like flange on the exhuast pipe going to muffler, which reduces the outflow, thus reducing the speed. Normally when you buy a new one, the dealer would remove the flange/washer from the exhaust connection. Did you check if you have any blockages in the exhaust piping? Its just a though to make sure that everything is flowing freely
Dean
Rome, Italy
'97 Honda SH50
'98 Aprilia SR50
'01 Gilera Runner 180
'05 Honda SH150
Warwick, RI, USA
'12 Kymco People GTi 300
'18 Kymco Xciting 400i ABS
'22 Kymco AK550 ABS
Viper254
  • Moped Pirate
« Reply #11 on: July 04, 2022, 02:21:51 PM »
I think it's possible we're discounting valve clearances too readily. They're quite often set too tight from factory, and this behaviour sounds about right for valves too tight - it's almost free or actually free to check them anyway
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
