Author Topic: Cell phone mount  (Read 992 times)
Hbfoxjr
Cell phone mount
« on: July 08, 2022, 08:30:49 PM »
Anyone have any good mounts since there is no handle bar exposure on these machines?
Re: Cell phone mount
« Reply #1 on: July 09, 2022, 12:46:55 AM »
I don't use a phone mount on my S200 but I checked the Ram Mount site and they offer a reservoir cover mount! Might be the easiest way to mount a phone on our scoots.
Edit - whoops!...was thinking about my Helix, which actually has an exposed brake fluid reservoir!
Maybe there is some type of mount that will clamp onto the mirror stem?
« Last Edit: July 09, 2022, 01:42:49 AM by Iahawk »
quochuy
  • aka Huy
« Reply #2 on: November 07, 2022, 06:13:53 AM »
I ended up buying a handlebar phone holder and built side mirror adaptor for it.
The adapter is composed of:
- An aluminium flat bar bent to an kind of 'S' shape. On one end a hole was drilled large enough to allow the mirror thread to go through. On the other end a hole was drilled to the size of a bolt.
- A short section of aluminium tube was cut and I drilled through it. This section was attached to the S bar above using bolt and nuts.
The handle bar phone holder was then clamped to the aluminium tube section above.
On my pictures, you could see some masking tape, this is because I chose a aluminium tube of too small diameter. The tape was to increase it.
2008 Kymco People S 200
« Reply #3 on: November 07, 2022, 01:43:50 PM »
nice solution for a phone mount!
