Did you miss your
activation email
Scooters - 125 to 300
LIKE 200i
Front fender nut or bolt
Topic: Front fender nut or bolt (Read 441 times)
kjems
Jr. Member
July 14, 2022, 11:25:19 AM »
Working on a Like that was stolen.
When installing new part provided from Ruffus I can't figure out how the front fender plate on the picture should be mounted. There is no nuts or bolts now, but they could have been removed by the thieves.
Also is it just mounted by the two mounting points and does it look correct with the gap to the black fender below?
https://ibb.co/g78jvBW
Kindly Jesper
Re: Front fender nut or bolt
July 14, 2022, 12:57:57 PM »
Jesper, this parts are connected by big plastic rivets (pls see pic)
July 14, 2022, 01:39:49 PM »
You can find bags of these pop rivets in varying sizes on ebay - and probably on amazon.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2553941.m570.l1313&_nkw=motorcycle+fender+rivets&_sacat=0
kjems
Jr. Member
Reply #3 on:
July 14, 2022, 02:00:25 PM »
Quote from: Ruffus on July 14, 2022, 12:57:57 PM
Great, just the info I needed.
Project is progressing - have desided to keep the red white look from Ruffus parts - a bit like the Danish flag
My hope is, it might also make it a little more recognizable and thereby less attractive steeling.
https://ibb.co/t3pNNX5
Reply #4 on:
July 14, 2022, 08:41:57 PM »
Good to see, here is your counterpart.
Back
