I check mine after every ride.
I let it sit in the drive on the center stand while I change out of my gear - come out in a few mins with a paper towel and check the oil "per the manual."
One scoot I wipe the dip-stick, screw all the way home, remove and check; the Kymco, remove and wipe, set stick in the opening, remove and look at it.
Owner's manual tells you which way to do it.
really dislike oil "windows'!! (off center-stand, hold level, sit on or sit off?!, kneel down in the puddle and look in that dark hole...some use a mirror on a stick, some use a trained monkey)
