Author Topic: Naraku 19mm v.2 Carb  (Read 1090 times)
Flyer23
« on: August 02, 2022, 02:28:48 PM »
I have a brand new Naraku 19mm v.2 with 24mm clamp fixation. Will a Malossi 23mm intake allow me to install it ? It looks like the intake will slide into the engine side of the carb and allow the clamp to be tightened, but having not done this before I am nervous so not to damage the new carb or to be able to return it. Thoughts ? Anyone do this before?
2StrokeVapors
Re: Naraku 19mm v.2 Carb
« Reply #1 on: August 04, 2022, 06:18:31 PM »
Not 100% but looking at the pictures of your carb, it looks like it should connect with the Malossi adaptor (without using the rubber piece).
I ordered the Malossi Dellorto kit below and it mount right up to the stock intake manifold and stock airbox (which I have derestricted using 1.5" radiator pipe)
https://www.scootertuning.ca/en/carburettors-sport-midrace/99006-carburetor-kit-malossi-dellorto-19mm-genuine-pgo-kymco.html
