Author Topic: How to remove the timing mark cover  (Read 2523 times)
Rickster
« on: August 16, 2022, 10:58:26 PM »
What's the best tool to remove the timing mark cover?  I've tried a large screwdriver, but it's just ruining the cap.
2007 B&W 150
2010 Yager 200i
Re: How to remove the timing mark cover
« Reply #1 on: August 17, 2022, 07:31:14 AM »
Got an old 1” chisel you could modify?
mrmike
  • Syuracuse, NY
« Reply #2 on: August 17, 2022, 09:58:15 AM »
   I'm not sure what you call these sockets. I've had them forever. They are 1/2 drive and made by Giller. I suggest you check the tool department of your local stores to see what you can find.
« Reply #3 on: August 17, 2022, 12:03:20 PM »
Probably a better suggestion than mine Mike!  😂
« Reply #4 on: August 17, 2022, 01:19:58 PM »
Any bigger  € or $ or £ coin with a diameter of 25 mm and a grip plier will do.
Rickster
« Reply #5 on: August 18, 2022, 05:04:49 PM »
Thanks all for your advice. I was able to successfully loosen that cap without damaging it too much. I placed the blade of a large screwdriver into the slot of that cap at an angle and gently tapped on the screwdriver handle with a hammer, which turned the cap enough to remove it by hand.
2007 B&W 150
2010 Yager 200i
