Author Topic: Fuel problem  (Read 2079 times)
Soundmed
Fuel problem
« on: September 02, 2022, 12:00:49 AM »
Hi all.  Hoping for some help.  I have a compagno 50i and it went a little while without use.  It started to studder at full throttle but is good up to about 3/4 throttle. I drained the fuel by running the pump, just took out and cleaned the fuel injector with brake cleaner and compressed air (while opening the injector with a power supply).  Started right back up with the same condition.  Any suggestions?  I didn't see a fuel filter but didn't dig.  Air filter is clean.  Scratching my head in this one...
Re: Fuel problem
« Reply #1 on: September 02, 2022, 01:25:01 PM »
You ptobably still have some "stuff" in the injector that needs back flushing to remove.
Re: Fuel problem
« Reply #2 on: September 02, 2022, 07:49:37 PM »
Re the fuel filter...if it similar to my LIKE200I it is in the tank on the end of the fuel pump in there. These filters don't clog.
