Author Topic: DT X360 battery charge  (Read 514 times)
TommyEu
« on: September 08, 2022, 06:50:26 PM »
Let it sit for some time during summer break(kids,wife, car,  bike had to stay locked at home...only for daily commuting to work and back)
 and now we're back from vacation after 5 weeks and  it wont turn or unlock.
How can I access  battery terminals to hook up a charger to fill it up and then key and all Will work.
Now it is locked in my garage, no power.
Thanks
« Last Edit: September 09, 2022, 01:16:03 PM by TommyEu »
Re: DT X360 battery charge
« Reply #1 on: September 08, 2022, 08:01:20 PM »
Hello, and welcome to the forum!
Is there a manual seat un-lock mentioned in your owner's manual?
One that does not require electrical power to operate?
If so, and if your battery is located under your seat.....
Also, I would think that your owner's manual will tell you how to access your battery - so that you can recharge it.
TommyEu
« Reply #2 on: September 08, 2022, 08:22:29 PM »
Thanks for the reply,
The key is wireless, no metal part...
And manual is inside the seat
Will call the dealer tomorrow and see what they suggest, Just hoped there is some access to charge it since key does not function w/o power
« Reply #3 on: September 08, 2022, 08:23:51 PM »
@TommyEu, welcome here too.
Two options (depends on model)
-open with your remote control
-open by putting your key into ignition lock and turn left.
There is another option, can't tell publicely. Only if your dealer cannot help, send me a PN.
Pls give a feedback, open for any further question.
« Last Edit: September 08, 2022, 08:28:43 PM by Ruffus »
TommyEu
« Reply #4 on: September 09, 2022, 07:46:04 AM »
I dont have access to battery or some wire that I could charge it off...
 I really would not like to have to break in my own scooter or have it towed to shop.
Just some way to give power so key can function and I Will charge battery once I can open seat via normal way.
There is one big plug  that looks promising?
« Reply #5 on: September 09, 2022, 09:04:29 AM »
Yes, follow that hint. You need not charge your battery, just put voltage into the system.
« Last Edit: September 09, 2022, 09:50:36 AM by Ruffus »
TommyEu
« Reply #6 on: September 09, 2022, 01:14:43 PM »
dealer reported that battery is not under seat but in front under windscreen/bodywork...
so that is the way to go, will undo few screws and report with pics for some info if others will need same thing.
thanks
« Reply #7 on: September 10, 2022, 01:23:55 PM »
It would be a wise precaution to hook up a battery tender once you have access to prevent a recurrence?
Welcome to the forum.
« Reply #8 on: September 10, 2022, 06:34:59 PM »
Kymco should supply one with each of these scooters!
TommyEu
« Reply #9 on: September 12, 2022, 06:45:04 PM »
4 screws that hold visor,
2 smaller ones that hold plastic hood
And there it is, accu :)
Video if someone else finds it useful.
« Reply #10 on: September 12, 2022, 07:49:40 PM »
Good to have, thanks a lot!
